No, I'm saying that cura used to print perfectly without fail for me. It would home X and Y, go up 15mm then slowly move down to the middle or the bed. But then maybe a week ago it started to move Y out as far as possible, homed X then would just start the print at that location. I have tried multiple files and each ends up being a glob about 1 inch long by 1/8 of an inch wide.
I don't know how to describe it other than that it just prints a big glob in a very small area instead of starting the print like it used to.
gr5 2,230
Are you saying Cura is different than other slicers?
Or that Cura changed recently? It shoiuldn't have changed recently.
yes, Cura does that. It extrudes faster than most extruders can possibly extrude so often it's not a problem but sometimes with hotter nozzle temp (due to temperature overshoot) or due to softer filaments I get the big blob.
I *always* sit patiently at the begining of the print and grab that blob with my fingers as it starts the print.
Some slicers are smarter and wipe the blob off along the front edge of the bed.
