Exact Z height ?
raytrace-nomad
Posted · Exact Z height ?
I'm so newbie , i'll ordered um2. I read manual of ultimaker and cura and i have some questions.
Using paper for calibration is no looks so afforable i guess
I have Z height gauge which i used to set tool height in my DIY CNC.
This tool has exact height (50mm) it has very accurate 0.01mm. If posibility to set Z height coordinate manually ( to -50mm after zeroing )
And other question is what is the proper height in mm ?
And here is the paper gauge chart.
I believe the proper height is .1mm.
After you perform the leveling procedure once I recommend you never do it again and do more accurate leveling as needed by simply turning the screws small amounts when you want extra precise leveling. You level by printing the skirt or brim of your object and if the brim is too thin or too thick you adjust the screws.
    • 4 weeks later...
    You can level very precise but the exact height still depends on the nozzle temperature as well. With temperature the nozzle expands. That is why the piece of paper (0.1mm) room must be there so that at print temperature the nozzle touches the bed. So your tool is probably too exact for this. I guess your CNC machine does not have that temperature limitation.
