Yes, It's starting to become rather annoying... probably becasue I always have about 6 instances of Cura running on the workstation. I'll copy something for emails, etc, and get the error warning which forces the Cura error window to pop up.
A workaround can be, open "c:\program files (x86)\Cura 14.07\Cura\gui\mainWindow.py" in a simple text editor, find the lines that say:
#Timer set; used to check if profile is on the clipboard
self.timer = wx.Timer(self)
self.Bind(wx.EVT_TIMER, self.onTimer)
self.timer.Start(1000)
self.lastTriedClipboard = profile.getProfileString()
(Around line 268)
And delete the "self.timer.Start(1000)" line.
Nooo! It's the one feature that I wrote in Cura :(
Nallath, you get an "A" for effort!
Thanks Daid, I will try that.
well, it didn't work for me...
In notepad, I opened mainwindow.py and deleted the line "self.timer.Start(1000)"
When I tried to open Cura, it hangs on the blue splash screen.
Luckily, I remembered to back up mainwindow.py
What did I do wrong? Can you not use windows text editor to make those edits..
Notepad might have messed something up... wordpad or notepad++ would have been a better option. As what I see in your notepad does not look like lines, but a big blob of text...
OK, wordpad was much nicer. Worked like a charm, so yeah, notepad bad
will this also work for 14.09?
Thanks Daid
Thanks Daid
Yep, same code, nothing changed there.
Awesome, thanks a lot Daid,
And thanks for all the hard work you guys put into Cura. I design models for customers, who often have Makerbots, so I have to load models into Makerware to test, and make sure they can print it fine, etc. I honestly don't see how makerbot owners do it.
So yeah, keep up the good work
Daid 301
While I know where this popup comes from, I cannot seem to prevent it. It's cura scanning the clipboard for Cura_profile strings. But it throws this error if the clipboard is locked at exactly the right time by another application.
(Maybe I should scrap the whole feature...)
