Peek threads stripped. Any US supplies of a PEEK ?
flyguy
Posted · Peek threads stripped. Any US supplies of a PEEK ?
My Peek threads stripped out and the hot end fell out of the peek during a print.
Does anyone know a place where I can get a replacement peek ? Preferably in the United states.
Thanks,
Brian
    My Peek threads stripped out and the hot end fell out of the peek during a print. Does anyone know a place where I can get a replacement peek ? Preferably in the United states.
    I'm not going to ask how you managed that...
    Mcmaster sells PEEK rods, 5/8in diameter, and you can machine it to spec yourself (1/4in drill for the well, M6 drill&tap for the brass tube) to make some form of rim on the top.
    http://www.mcmaster.com/#peek-rods/=howphm part 8503K232
    while you are at it, you could consider scrapping the 1/4in well on top, and replace it with a section with an M7 tap, and also thread the bowden with a M7... this will eliminate any bowden decoupling events.
    If you end up making your own, I agree with Joergen, thread the bowden. I threaded mine M6 to fit the existing PEEK part and I never have problems with the hot end clogging or the bowden popping out.
    Take a look at scottmayson's insulator here-
    http://www.thingiverse.com/thing:20535
    I think that would be a nice upgrade (in PEEK) if you have the tooling.
    Kyle
    I ended up ordering the 5/8" Peek Rod from mcmaster, with a M6 tap and the appropriate drill bit. I like the idea to die the bowden and tap the top of the Peek.
    I'll have to pick up the appropriate tooling for ACE hardware or home depot.
    Also I picked up a $120 mini wood lathe from harbor freight.
    I already had a mini drill press.
    lets hope for no more hot end issues !!!!
        • 56 replies
        • 29 replies
