Don't switch filaments around. Switching from ABS to PLA is especially prone to causing clogs. Especially since you are still new with this printer. Stick with PLA if you can. Or at least stick to 1 and don't switch until you have a successful print. Try 245 for ABS or 220 for PLA. Don't go any hotter until you get things working somewhat. Also start out slow - print 30mm/sec and .2mm layers at first until things are working well. Only after that try thinner layers, higher speeds, higher temps (or lower temps) and so on.
For cleaning the nozzle you could try the atomic method:
http://umforum.ultimaker.com/index.php?/topic/4118-blocked-nozzle/?p=33691
IRobertI 497
You probably put the feeder back on backwards (don't ask me how I know...). Looking at the feeder, the white pressure indicators should be on the right side.
