More fan they say at www.3dVerkstan.se, when printing ABS.
thanks, i have read it on the homepage, but with the 50% fan setting, it works not so good as with 25% at my tests. I will test twice and i´ll give you responce, if you want?
my next prototyp is a Box with an wideness of 22cm LxB. The hight of the box is 10cm. I need this box for erlectronic parts to control heaterpads for international Liquid transdports in 20´containers. It should be strong enough for handling on the viennies harbor. that is the point, why i will useing the ABS Matireal. Now i have made a bottom testprint and the bottom is not flat. what can i do, to have a flat bottom in my box. can I stop it with vertical webs in the box?
cheers
GBUM 3
thank you for your help. I have done the atomic move and the filament was clean. i used the ultimaker for maximum 10 hours bevor i start with the abs matireal.
now i print with the fast print stting and the following tempretures.
245°c noozle
110°c plate
25% Fan
and it works. i will testing step by step to an higher quality level and hope it works too.
cheers and thank you
Edited by GuestLink to post
