top layer- the distance between the lines of plastic
ksn-arts
Posted · top layer- the distance between the lines of plastic
Thanks, I missed that thread. I'll make sure to read it and follow it. We've been using both OS X and windows versions of Cura and I just recently had the same issue with 14.09.
    • 2 weeks later...
    It really is worth trying a different material. I have just completed printing a chess set; for the "white" I wanted to use Faberdashery Buttercream - never used it before. Whatever settings I used I suffered delamination between the outer walls (never seen this before). As soon as I switched to their Arctic white, perfect.
        • 27 replies
