Posted · Stepper Driver
My Ultimaker has finally died after several weeks of intermittent faults.
Now it have found that one of the stepper drivers is crashing everything, if i unplug it the ulticontoller works, plug it back it everything goes blank or starts the stepper motor it is plugged into pulsing.
One of the other stepper drivers has a bit missing see photo.
Does it make sense for a stepper driver to have this effect?
stepper driver one faulty the other with a bit missing
    Those are UM2 step sticks right?
    They look quite like the "ice blue" step sticks you'll often find bundled with eg. Ramps boards:
    http://m.ebay.co.uk/itm/221281785267?nav=SEARCH
    But otherwise I guess Pololu black yes...
    And do be careful with the current, I just fried some pololu purple sticks, by going too high...(partially due to not knowing which way to turn the pot to increase and decrease current)... Start low and slowly work your way up until the stepper no longer skips steps (apply a little resistance to the printhead with a finger or two when testing)
