Just visited out repair&production center, put an old printer next to a new one. The colors of the LEDs changed a bit, but the brightness is about the same. So you might have a faulty LED strip. They offered to send you a replacement if you want.
both strips faulty? what are the odds... I'd love some brighter led's, thanks
The odds are close to 100% if both strips are from the same lot and the whole lot is faulty...
Could it be that your second printer was assembled by fbrc8 and they have a different source for the LED strips than the production in the Netherlands?
No, I ordered from the NL's. I was saying the "what are the odds" thing becasue i too thought it would have to be the whole lot, certainly not just 2 strips. If that were the case, others would have chimed in, surely, stating their LED's were not bright. But that doesn't seem to be the case....hence "what are the odds"
I just thought I'd bring it up to Ultimaker becasue if it was an entire lot, it's easy to miss until they compare that lot side by side with another lot, or older UM2's.
Can you still dim the LEDs on the new printer? Looks a bit like what happens when the dimmer goes bad.
Yes I can still dim the lights, but it's really a narrow window. I either have kinda dark, really dark, or off.
It might be my imagination, but the lights seem to be getting darker as time goes on. I'll have to do another side by side photo recreating all the variables to see if I'm losing it
it's really not that big a deal to me, just thought I'd share with the Ultimaker team in case they start running into this problem more often, they'll have an idea of what's going on.
hard to tell if it's getting darker from an updated side by side (probably just me), but it's freaking dark for sure...
I took the original with my iphone so I couldn't lock in aperture and shutter speed to compare mathematically in photoshop. I did do that this time
To even out the brightness, I have to set the older UM2 to 25%
OK, I gotta resurrect this topic
Nobody has dim LED's but me? (Sept model with the encapsulated LED's) Does anyone know of a way to test parts to see what's causing this?
You're not alone but i guess that it's something that you spot only if you have two um2.
Here's a pic from one of the french section:
Being new here, I was wondering if some folks are still noticing any dimming of leds on the UM 2. We purchased our mid December 2014 and when we helped the local Library set up their new UM 2, the first thing I noticed was how bright theirs was. I double checked the settings on both UM's and both were at 100%. But mine was noticeably dimmer. Any input would be great.
I got my ultimaker back in october and my lights are compleatly dead
Daid 306
Your topic has been noticed and we're investigating this. (Nothing but surprise at the R&D department so far)
