Spare Linear Bearings.
Posted · Spare Linear Bearings.
I don't have a supplier for you (except if you can order as a company and not a private person), but maybe I can help you specifying what you need exactly.
You're looking for a double length linear bearing for 6mm shafts:
Shaft diameter: 6mm
Outer diameter: 12mm
Length: 35mm
The Misumi article no for this would be:
LMUW6 (bearing steel, non-stainless but very hard. Recommended)
SLMUW6 (stainless steel)
But Misumi only accepts business customers :(
/edit:
Ultimaker uses the article no "LM6LUU" (from another manufacturer...). You might find something with this...
    • 2 weeks later...
    • 1 year later...
    Were the ones you bought any good?
    I bought a set of 4 on ebay which were, in theory, of a reasonable quality, but they were nowhere near as quiet/smooth as the originals.
    Currently still seeking a couple of these for my printer.
