ultiArjan has good advice. There are several fixes but I like ultiArjans. Did you design this part? Consider:
1) Flip part over.
2) Instead use bridging.
Bridging is easier to print see photo here:
http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#overhangs
ultiarjan 1,215
Best solution is to avoid overhang by changing the orientation you print the object in. Rotate in cad or in cura.
Think this is a good option in your case. Otherwise you need to use support... but this will always be a less nice surface...
