2 top layers
torvine
Posted · 2 top layers
Hi;
Had my ultimaker for a week now, Could not be more pleased with it !
A quick question........
Picture printing 2 cubes one larger than the other ontop of each other, Like a sugar cube on a box of matches....
Is there a way to improve the top layer on the bottom cube..? The top cube top layer always seems better..?
    Would you mind adding a picture of the case to solve? There are so many things that can be going on...
    There are no special case for the "real" top of a print. Any part that is getting toward the surface gets the required top/bottom shell thickness.
    Is the top of the bottom cube completely closed or is it hollow under the top cube? Its pretty hard to stop a layer in mid air if there is no support under it.
    You should follow topics you create to see when people reply to them. You can do that on the upper right part of this topic or in you profile settings.
