gr5 2,196
There are many possibilities. What you describe sounds like it might be underextrusion although the picture doesn't help very much.
You may be right about the temperature. You can test the temperature with this method:
You can test for other causes of underextrusion with this test print which must be done at 230C:
http://umforum.ultimaker.com/index.php?/topic/4586-can-your-um2-printer-achieve-10mm3s-test-it-here/
