DidierKlein 729
Yes there are a lot of differences between filaments brands and even colours of the same brand...
You can print with colorfabb at 190°c but in case you print small layers 0.1mm or less and slow (30mm/s) if you want to print faster you can go up (way up) i sometimes print colorfabb at 240°c usually at 230 or 220°c
skint 61
I do find differences in the manufacturers of the PLA bob, aswell as differences with colours. More likely that than the machines. My typical temp is around 195-200. Just bought some colourfab bronzefill![:)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
