combing + always retract ?
izo2
Posted · combing + always retract ?
hello, i didn't find a way to use combing option and always retract on travel,
so i have an object where the surface need to be clean, but i see all the travel line on it :(
if i don't use combing, it's perfect but as it not avoid hole anymore i sightly have more stringing on it.
so for me combing + always retract will be the perfect solution.
    hi myself, you should read the forum
    :lol:
    Yes. But I agree it would be nice if Cura had an option instead of having to use the plugin. Is this a top layer? Bottom layer? There are other solutions for top or bottom layer that makes it even more perfect but the plugin is a good option.
    top layer,
    i read about print a small full layer on the top and clean the edges by hand.
    but already when i had to remove a brim i never had clean edge :(
    so i guess this method is not for me.
    if you have other method , let me know
    thks
        • 24 replies
