Ultimaker 2 + Cura + Pronterface = print bed not raised when a print starts
cagy
Posted · Ultimaker 2 + Cura + Pronterface = print bed not raised when a print starts
Hi all,
With this config:
  • Ultimaker 2
  • Cura prepared gcode
  • print via Pronterface
I have this result: print bed not raised when a print starts, print bed stays at the bottom of the printer, the extruder starts moving around and prints in mid air.
How do you tell the software to first raise the z-axis (print bed) to the correct height?
Thanks!
    I'm not sure as I haven't printed via USB on the Ultimaker2 (as it is not recommended) but I think you'll have to change your Gcode flavour to RepRap if you want to print via USB. You should be using the SD-card though, it's much better.
        • 6 replies
