yellowshark 153
Also if you have a 1st layer height of 0 then that will cause you problems After you have re-levelled the bed, and check it carefully and again, set 1st layer height to .300 (do not go below this whilst learning, it only makes life harder). Try reducing extruder temp to no more that 220; you don't say what your print speed is but 220 should cover you for most things and certainly OK for 1st layer. Have fans turned off for the 1st 2 layers (no fans on 1st layer!!). Probably set fan to max 40-50%.
Do you have a digital thermometer/ If so check the bed is 60 pretty much all over for a large part before starting print.
Dim3nsioneer 559
Relevel the bed as the distance between nozzle and bed is a bit too small.
