However getting M3 threaded rod can be difficult in the US, I guess... It's just smaller than 1/8th of an inch, so that won't fit. If you cant get metric get the largest size smaller than 1/8th.
If all else fails, just run with the three of those screws. You will need the three that are closest to the extruder. Hmm. The fan might dangle a bit.. Hold it up with the screw you have hold the other side in place with the one that's broken. Or just anything that's straight and fits.
Daid 300
Threaded rod will work. Would be a bit harder to install, but it will work. Initial Rev1 machines had threaded rods.
