Posted · What's the ID & OD of Colorfab's Spools?
Just as the topic says. I know different manufacturers use different size holes for the ID & OD of the actual plastic spool that holds the filament. I haven't used Colorfab's filaments yet. I plan on buying a bunch of Colorfab filaments in 1.75mm and need to know the exact dimensions for my custom spool holder which needs to be accurate. Can anyone post here of the fixed or various dimensions?
    Probably most people here use 2.85 but i assume colorfabb uses the same spool for both? Not at home atm but can measure tonight if no one else reacts earlier.
    Other question. Does anybody know if you get a spool now when you order at faberdashery? And if yes what size they have?
    Hey Chrisp
    ID = 53.0mm
    OD = 200.0mm
    Width = 54.0mm
    Just opened a brand new Bronzefill just for you :)
    Skint....thank you sir!
    I just modified iRoberts spool holder to work with my build since it is fully adjustable.
    Faberdashery - orders for 100 mtrs come on a spool. All other quantities come loose. I usually order 50mtr quantities to avoid receiving a spool :)
