Thank you
I have a go at Fix horrible, I take it there’s a factory reset Just I case
.gromit
Thank you
.gromit
If you use "xray view" in cura it will show in the color red any problems (missing walls or extra walls). Also if there is no red seen then you might want to *uncheck* fix horrible.
Fix horrible will not modify your stl file. So don't worry about that. It just modifies the slicing algorithm to fix things on the fly.
Yes that did it thanks, In Fix horrible set to keep open faces,
Now what you draw is what you print, As long as you draw the way the printer prints.
Maybe keep open faces should be default?
Gromit
No as it may fix some "bad" models but it can mess up a perfectly good model.
CAD programs like "google sketchup" are meant for creating computer graphics and allow you to place triangles/planes/2D objects anywhere. They don't work so well for making prints.
CAD programs like solidworks only create 3D objects (not 2D objects) and are meant for designing real things that exist in the 3D world. They work great with Cura and all the "fix horribles" can be unchecked.
IRobertI 516
I'm guessing there is an error in your STL file. Usually playing with the "Fix horrible" settings will take care of it. See more info here:
http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#randomfill
