I have supports on the inside, not outside.
Other items with internal support print correctly but they do not have an overhang.
It is an easy problem to troubleshot since no printing is necessary- it can be seen in Cura's layer mode.
You are correct, I just tested it and turning off the support I get a properly touching brim that is also round. Turning on the support the result is as in the the picture.
DidierKlein 729
Do you have support structures for this one? I have these kind of brims when i have supports
