Excellent! Thank you!
I'll update when I get back to work tomorrow & do some prints.
Daid - how does fill density and wall thickness affect quality? or do you mean quality to be 'structural quality' as opposed to (what I assumed) 'perceived beauty of the object'?
The part also will be stronger, but the infill is also better to hold up the "roof" so to say. I found that with thin layers you better have a bit more infill.
Back again.
Tried out adjusting some settings, but have run into a probelm - overlap.
pink sections are the problem - green is fine - the outer overlap works, but not the inner - any ideas?
Also, the seam evident in this picture:
Is there a way to avoid this seam by randomizing the layer order (like netfabb does?)
Backlash problems, most likely because of lose small belts.pink sections are the problem - green is fine - the outer overlap works, but not the inner - any ideas?
The setting that does this is called "Jitter", but you cannot access it from Cura.Is there a way to avoid this seam by randomizing the layer order (like netfabb does?)
I don't get this behaviour in repG though, will check belt tension, but believe it to be good.
Hallo,
how to solve the Seam and Overhang Problems in last picture?
I got such Seam every time the nozzle stops to move z-Axis.
And the Overhang is a problem with the fan (need better fan cooling)? The rest of the surface looks good for the temperature.
Hallo,
Yes, Daid must implement Jitter
Daid 303
Sure, most settings are the same as Cura's defaults. The details can be found in simpleMode.py. But the main differences are:
Layerheight 0.2 for normal, 0.1 for high quality.
Wall thickness 0.8 for normal, 1.2 for high quality
Print speed 50 for both
Fill density 20% for normal, 30% for high quality.
