Posted · Support options are disabed
Hi.
I opened my Cura today intending to do a print, and I found my support options (Support and Platform Adhesion types) are disabled. I rebooted but that didn't fix it.
I am using Cura 14.07 on OS X. (I tried 14.09 and had some trouble with it.) I installed a copy of MatterControl, which uses the Cura engine, but I don't see how that could be an issue.
Anyone know why this would happen?
Thanks.
    It's a known problems with the Mac version. You might need to resize the side panel a bit (you can drag the split between the 3D and settings area)
    • 5 months later...
    Your suggestion didn't work for me. This is a very annoying problem and some time it take ages to make this change. Any other possible fix?
    I have the same problem when I start cura with a click on a .stl file.
    When I start cura direct and load a .stl the drop down works.
    I just solved it by closing Cura and opening it again.
    Celso
