I tried with another part, which is smaller.
Still same behaviour of the motor. Now, it does it even during print of the part body.
I tried to keep pushing by hand the filament. It is clearly pulled back by the motor.
I also sensed the axle protruding from the extruder. If it is the motor axle, it is also going back.
And again, lowering the speed from 80mm/s to 65% (about 50mm/s) solved the problem.
I will do more tests.
Angelo
IRobertI 516
I would check your bed levelling to make sure it's proper. If the bed is too close to the nozzle the pressure will be higher which can cause the motor to skip back.
The skip back is mechanical, it's not controlled by the electronics (more so than controlling the amount of current the motor receives), that's why you're not seeing the printer compensate for it after it happens.
