Side fans wont turn on
kristoffer
Posted · Side fans wont turn on
Hi
I printed a 40 hours print over the weekend that came out fine.
I tried to start another print, but noticed that the side fans didn't come on. The speed was at 100 % in the tune menu.
I checked the wires and the green connection was broken.
I fixed it, but when I tried to check the fans again, there was a noise like a short-circuit and it smelled like that too.
I checked the wiring and they are as they should be.
Is there a way to check the connections/main board, in case the problem is somewhere I can't see?
    Yes, and click "raw" to get the pdf. Go to page 55 of 69 and in top right, step 16, examine the colors of the 3 wires related - one wire (green in photo) should connect the two fans together to make them "in series".
    Smell of smoke is a very bad sign.
    Check the voltage at the fan connectors - each fan should be 12V (24V across both fans). If one fan is shorted or open you will see 0V across one fan and 24V across the other.
        • 24 replies
