UM2 rod movement
minestorm
Posted · UM2 rod movement
Push the rod back into place. Loosen the set screw on the pulley on the side that was poking out, hold the rod in place and push the pulley towards the wall of the printer as far as it will go and then re-tighten the set screw tightly and you're done.
