now all we need is for Cura to shut the pc down after the print is finished...
fboth do you think you could explain a bit more (with pictures) so electronical idiots like me can understand?
thanks
I am delighted by the idea of suicide option. Such notifications can be taken easily.
fboth 0
Dear Daid,
I made it even simpler.
I just connected a solid state switch: Selectron HRT D 4805L to Arduino
A0
I connected a simple on/off/monentary switch to the 2 240VAC pins of the solide state relay.
At the end of print I insert the M81 command
It works fine
Regards
Franz
