Ultimaker - suicide!
Posted · Ultimaker - suicide!
Now that's a headline to grab attention. But nothing to worry about.
I added an suicide option to my Ultimaker, so it can switch off after printing. I've done some documentation at:
http://daid.eu/blag/2012/07/03/ultimaker-suicide/
Photos will follow a bit later.
If people are interested in this upgrade: I still have parts to do this 4 more times. However, the parts are less expensive then the shipping. And most of the work goes into soldering, wiring everything up. But I wouldn't mind helping building/installing this into dutch machines at the next UltiEvening for example.
    • 7 months later...
    Dear Daid,
    I made it even simpler.
    I just connected a solid state switch: Selectron HRT D 4805L to Arduino ;) A0
    I connected a simple on/off/monentary switch to the 2 240VAC pins of the solide state relay.
    At the end of print I insert the M81 command
    It works fine
    Regards
    Franz ;)
