If the filament is oversize then it may have trouble getting through the gap between the drive cog and the idler wheel (bearing). You would have to back off tension. If the filament has a tight curl then it's possibly just getting hung up somewhere.
Not only is it easier to tweak the tension on this feeder, it's also great for quick filament changes: you can manually poke the new filament into the bowden tube before closing the tension arm, so the problem you describe simply couldn't occur.
donmilne 2
I would recommend a switch to Robert's feeder.
https://www.youmagine.com/designs/alternative-um2-feeder-version-two
...or the variation on it which I actually use.
https://www.youmagine.com/designs/yet-another-ultimaker-2-feeder
