I can't understand what's wrong with my printer
Posted · I can't understand what's wrong with my printer
Hi there,
I own a Ultimaker2 for 5 months and i always have some problems...
I'm trying to print the "bed level file" that the support gave me, but while printing the 1 layer in some points the filament doesn't stick to the plate.
I regulated the plate several times, and cleaned the nozzle, but the filament seems to stick to the nozzle sometimes or doesn't come out at all, i thought the problem was the plate too close to the nozzle but even if i put it lower the problem is still the same.
i put some glue on the plate as suggested before
any suggestion?
    A few details that would help troubleshoot the issue. What material are you using, the temperature of both the nozzle and bed and the layer height you're printing with?
    In regards to bed leveling, refer to the topic below, specifically Illuminarti's post for the correct procedure to get a level bed.
    http://umforum.ultimaker.com/index.php?/topic/8330-best-procedure-for-leveling-the-bed/?hl=%2Bbed+%2Bleveling
    thanks guys,
    i found Illuminarti's post very usefull, i did the procedure but my filament still doesn't stick to the plate!
    seems to come out and stick to the nozzle only.
    i'm printing with a PLA material, noozle temperature 210 and plate 60
    Plus, i don't know if it is relevant but i noticed that even when the material comes out free, like in the beginning of a print session, the material always seems to be attract to the nozzle, instead of go down the filament goes up and stick to the nozzle, i always have to push it down with a pen or something before the print starts.
    is it normal?
    thats quite normal duffy... happens a lot. What version of cura are you using? I find that 14.12.1 tends to push more material out at the start which can help it flow a bit before it starts the print.
        • 24 replies
