Can you break up the STL and print the watch and charger separately?
Also, with the rotation tool, hold shift to rotate per degree instead of per 15 degree steps
No freaking way..... Had no idea you could do that, thank you
Okay, and what about the watch it self? If you go on thingiverse and go to thingiview and rotate down to the bottom, the watch has a sort of circular charger at the bottom and when i tried to print it, the printrbot would print the charger perfectly but then it wouldnt print the watch because it dosent have a support to go on. Any ideas?
You need support to print that. The file is not separated like its show in the images. I would flip the model upside down and try to bridge the whole top. There is a "screen" that covers it so its irrelevant how it looks inside.
tottenham12712 1
In cura, click the rotate option at the bottom left of the viewer. Than click the top icon "Lay Flat", I actually had to click it twice to get it to lay 100% flat but it did work. Hope that helps!
Daid 306
subwaydude 0
