Thanks very much for the ideas!
I got it sorted by removing the PLA (via the automated removal method) and then cutting off the grinded section of PLA (from the feeder knob) and cutting the end at an angle and then reloading the PLA. Now it works fine.
Did I really need to discard the grinded section of PLA? (I hate waste).
Thanks!
IRobertI 497
I've had this on quite a few printers lately. Usually it's a case of the filament getting caught on the edge of the white piece in the head (the teflon isolator). For that problem it usually helps cutting the end of the filament so that it's more a point (you can yank the filament back out when you power off the printer).
In other cases it's leftover PLA in the bowden tube getting bunched up as the new filament is being pushed in. It jams, again, right at the entrance of the teflon isolator. Sometimes it helps to pull on the filament as it is loading so that it skips back a cm or two and then let it feed again. Sometimes it helps by helping the filament along by pushing at the back of the printer.
In rare cases I've had to remove the bowden tube at the head and clean the old PLA out (very rare though).
