oliver3d 2 Posted February 2, 2015 in UMO enclosure Hello fellow printaholics! Today i wanted to share with you my soundproofing enclosure that i made for my UMO. It's kind of a "poor mans edition", and not the prettiest, but it fulfills its purpose well! I made it with stuff I found in a scavenger hunt in our garage. The only thing i bought was the led lights and some more soundproofing material. I made this for three reasons; 1: I'm running the printer in my living room, and you can all guess what my girlfriend thinks about the noise it made. Of course I too found the noise a bit much at times. 2: To keep the temperature steady and prevent drafts. 3: To keep the fumes etc inside the box instead of my nose. What is started with. An old top piece of a closet. I cut a hole in the door for the plexi glass. The box wasn't high enough for the bowden tube, so I cut a hole in the top, and built a "box" out of plywood on the top to allow free movement of the bowden. I then added some foam pieces for some DIY soundproofing. I also used silicone ti air tighten all the cracks. I at least tried to make it a bit less ugly by painting it. Cut a hole in the back to simply stick the extruder motor and feeder mechanism out through (this is something i'm coming up with a new solution to, as it is hard to change filament like this.). Added the first pieces of various soundproofing material. Followed by more 2cm thick soundproofing, the kind which is use in boats and engines. After I added some LEDs, I had an almost finished product! I still intend to install a fan with an air filter, not so much for temperature control, but for the release of fumes. It really keeps the sound in well. The extruder motor is outside the box, so that makes a bit of noise still. I'll make some kind of box for it, after i'm done with deciding how to place the whole thing. The ambient temperature during a print is about 45C. All in all I'm happy with the result. Share this post Link to post Share on other sites
pm_dude 26 Posted February 3, 2015 in UMO enclosure Cool. I'll be making something like this hopefully in a near future. That is a pretty well detailed step by step. Thanks for sharing Share this post Link to post Share on other sites
oliver3d 2 Posted February 3, 2015 in UMO enclosure No problem man. I was hoping someone would find it useful for making a project of their own Share this post Link to post Share on other sites
cloakfiend 632 Posted February 20, 2015 in UMO enclosure I wish i could do that to my entire flat, lol. Share this post Link to post Share on other sites
