Plugin question
jeroen-somers
Posted · Plugin question
Hi there all,
I don't know if its been asked before (I've looked but couldn't find it).
I am writing a Cura Plugin to display the current .gcode file that is selected from the SD card.
Only I can't get the plugin working so maybe you could help me out here.
What I want is that the message >> M117 Printing... <<
is replaced with >> M117 ("filename".gcode) <<
This is my plugin so far:
#Name: Display Name
#Info: Shows the name of the file on the display.
#Type: postprocess
import re, os.path
def getFilename():
return os.path.basename(filename)
with open(filename, "r") as f:
lines = f.readlines()
with open(filename, "w") as f:
for line in lines:
if line.startswith('M117'):
filename = getFilename()
f.write("M117 " + filename + '\n')
else :
f.write(line)
what it does, it replaces the printing message > M117 Printing...
with this >> M117 CuraPluginTempz3u6ub
This isn't my ("filename".gcode)
This is some random temp file that is made when you save your cura model to .gcode
If you need more information just say so.
I hope someone can help me with this
With kind regards,
Jeroen Somers
    The plugin runs before you save the file. Therefore it cannot know the final filename. The only thing it can know is the name of the temporary file created by Cura and handed over to the plugin.
    But the filename is created by the model you load, this model has a name and when you save it it becomes (modelname.gcode). And the model is loaded before the Plugin.
    Isn't there a way to get this name?
    A simple solution could be if cura would create a random directory and give the file its normal basename. But yeah, this might need some cura changes. At some point the start.gcode had placeholders for the filename, but they were never replaced with the actual filename.
