dirkdirk 5 Posted February 9, 2015 in Cura-Plugin request Hi, I 've noticed after prolonged testing that the surface of the print is a lot better if the fan is disabled. See this post: http://umforum.ultimaker.com/index.php?/topic/5375-top-layers-not-touching-um2/page-19&do=findComment&comment=93213 Therefore, I am asking whether someone can write such a plugin. I know it works with tweak at z but only with input from layer- nr , fan speed , etc. It would be simpler to say: Disable fan on the last layer. With a checkbox for activating or deactivating. (Like in the current version of retract while combing with first and last layer only) I would write it myself but I have ( unfortunately) no knowledge about programming. :cry: thank you greets dirk Share this post Link to post Share on other sites
pm_dude 26 Posted February 9, 2015 in Cura-Plugin request That would work only in that specific case. You probably want to do it for the top infill only and maybe not for the perimeter. Share this post Link to post Share on other sites
Dim3nsioneer 360 Posted February 9, 2015 in Cura-Plugin request I could introduce a behavior 'Apply to last layer only' in TweakAtZ... Share this post Link to post Share on other sites
dirkdirk 5 Posted February 9, 2015 in Cura-Plugin request That would work only in that specific case. You probably want to do it for the top infill only and maybe not for the perimeter. I think the m106 s0 or m107 must be added after ;TYPE:SKIN in the last Layer or? I could introduce a behavior 'Apply to last layer only' in TweakAtZ... This would also be helpful. Share this post Link to post Share on other sites
