It doesn't have to be isopropyl alcohol - you can use other strong cleaners. Maybe paint thinner or maybe acetone. I'm not really sure what else works. I have been to the Netherlands and find it very difficult to believe you don't have this product in your drug stores - maybe it has another name? In most countries it is found with the bandages:
gr5 2,331
There's lots of tricks. Since you have no heated bed you might have to go old school: raft.
When you used the blue tape did the tape lift off the bed? If so use wider tape. Also did you clean the blue tape with isopropyl alcohol? Found at any store that sells bandages. Wiping with alcohol cleans the wax off the tape.
Also when you print is the bottom layer squished nicely into the cracks of the blue tape? You want the first layer squished flat like a pancake.
Anyway, consider using the "raft" feature. This is how old reprap printers were able to print ABS without a heated bed. The raft absorbs just enough of the warp (just a tiny tiny bit) such that the part doesn't come off the bed. It warps but such a tiny tiny amount that you can't see it visually.
Aheated chamber helps (enclose the 3 sides with clear plastic wrap and put a box on top - then put a hair dryer in there for 10 minutes, then turn off the hair dryer and start printing). The glass temp of ABS is about 100C and room temperature is about 20C. You get about .6% shrinkage in that range and that causes all the problems. If you can heat the air half way (60C) then you get half the shrinking (about the same as PLA which cools from 60C to 20C and does about .3% shrinkage).
carinac 0
Haha, I like the heated chamber :cool: I'll try that. I live in the Netherlands and it is very cold here (5-7 degrees), but nevertheless I printed with window open as ABS is not a very healthy air. So it was freezing in the chamber, this might be the solution, thanks a lot.
If not I'll try the isopropyl alcohol, although this isn't available in the Netherlands, unfortunately, but I'll buy it by the internet. As you did advise me that before and I didn't do it...
The raft I tried but the tape comes off anyway. Wider tape will probably not prevent that, as it really comes high up (about 4 mm), very clear visible.
Thanks!
