Think you meant for this to be in the other thread....
[edited by gr]
[edited by gr]
Moved alternate nozzle size discussion to other thread! This thread is for discussing what is in the original post.
Im not changing nozzle size just want to remove the fans so I can fit more on at once
If you look at the stuff I print at mrdesignworx.com you will understand what I need.
ultiarjan 1,218
no I did not, but did you also think about the gantry height? you'll still have the issue of items higher than 48mm being knocked over by the axis if you fill up the bed.
