Buying ninjaflex
x3nomorph
Posted · Buying ninjaflex
Hello,
i plan to buy a ninjaflex filament, but when i want to order it my shipping costs are almost bigger than the filament itself....
I am from europe, does anyone know a trusty reseller of the ninjaflex filament?
I found it on:
http://www.makergeeks.com/
and
https://www.lulzbot.com
if anyone buyed from them and they are trusty then tell me please.
Thanks in advance.
    i just ordered some from E3D with some nozzles and shipping was pretty cheap in comparison to other places
    Haven't used the other companies that you have listed though.
    Thanks, i ordered today a test filament from them too :D if there be problems, its your fault! :-P
    Im trying first their e3d filament, after that i will order ninjaflex. Yea, their shipping costs are low.
    Cheers
    Hi Guys,
    There is another newer product available from the same company.
    The Name is Cheetah
    Is supposed to be more compatible with UM2
    http://www.ninjaflex3d.com/products/cheetah/
    They have more products coming out too.
    You have to find resellers
    Good luck
    Posted (edited) · Buying ninjaflex
    It has a listed shore hardness of 98A, that doesn't sound very soft to me. That's in the "hard" range on the scale. No wonder it's easier to print...
    Old thread, but always new viewers using the search command:
    Reprapworld.com is selling the original Ninjaflex and semi-flex. = Low shipping costs for the Dutch community and countries closeby.
    Works perfect for now on UM2+ (240 degrees, 20mm/s, no retraction). Only printed relatively small parts untill now though. Cannot judge for bigger parts.
