Brim settings
kirash4
Posted · Brim settings
I'm printing some gears that have teeth on the inside. I need the outside brim to hold the piece down while printing and I'm using 15 lines), but I don't want/need the inside brim. It's a pain to clean it up between the teeth of the gear. Is there some way of controlling this? Using the latest Cura version.
    If you find a way, let me know :p
    For now, I manually add brim in the modeling program when it needs to be controlled. If my initial layer height is set to .2mm, Ill add a .2mm brim to the part and cut out areas I don't want it.
    Try a skirt instead of a brim.
    It does not always work, but most of the time skirt is on the outside only.
    Set the skirt distance close to zero (but not zero -- e.g. 0.05mm)
    A skirt isn't enough to hold the part down, which is why I'm using a brim. Guess I'll do it in the modeling software.
    Correction: a skirt might work. I had forgotten that you can change the amount of lines that the skirt lays down. So if I set that to 0.05 for distance and tell it to lay down 10-15 lines, that ought to be enough. I'm off to try that right now.
    Right: a brim is just a skirt with no spacing...
    My experience is that if you enter 0 as distance it just behaves as a brim, but with a very small spacing it won't fill the inside -- 0.0001mm might even work. it is easy to check and experiment with the 'Layers' view...
    Yep, setting it to no brim and letting it build a skirt instead wors perfectly. It only does the outside and ignores the inner gaps.
    that help a lot for me too. thanks :)
