Ok sorry I fixed it, looks like I didn't publish the photos :oops: , ok that was what I thought was happening, So I tried to re print at 240c with a resolution .1 and a speed of 100mm/s and got a different error. I uploaded pictures in another album
The print started fine and was going good with a lot of it I think(I tried to sleep during the print which was impossible with the fan being so loud) But when I got up in the morning to check it some weird stuff happened to it. The bottom face that should have been finished by time it built the walls up have holes on the top layer like where is tried to fill it in but didnt lay out any filament or something. The same thing on any edge that should have been finished except on the arch part for the half cylinder. Also on the walls at the later end of the print they are really flimsy and looks like the support material but it shouldn't. It's like it also didn't get enough filament. Any help would be very appreciated thanks,
Temp:240
Res:.1
Speed:100mm/s
Brim
Support everywhere
gr5 2,194
I don't see any images in the gallery.
210C and 100mm/sec and .2 layers and .4 nozzle is - well too fast. At that cold temperature the PLA is like toothpaste and at those speeds you need probably 20 pounds of force to get all that PLA out the tiny hole although it can only put out about 10 pounds force. Here are suggested max speeds for .2mm layers (for .1mm layers you can print twice as fast):
20mm/sec at 200C
30mm/sec at 210C
40mm/sec at 225C
50mm/sec at 240C
If you want a decent looking robot go for 240C and say 60mm/sec. If you want a gorgeous robot go for 210C and 30mm/sec.
