PLA and SCUBA
Posted · PLA and SCUBA
I've been thinking lately of things I could fab up that would be helpful when SCUBA diving. I'm really not sure of how PLA would stack up in the water though.
So this is a two part question. One, would PLA hold up vs various conditions underwater? And if no one is sure, maybe put together a bunch of test scenarios and I can just bring some PLA with me on the next dive.
So here's a list of conditions:
- Pressure at various depths (up to 130ft).
- Colder temperatures (I'm diving in Canada, its cold eh).
- Warmer temperatures (when diving on vacation). I know the glass transition temp is pretty low, but I don't think the ocean ever gets that hot.
- Constant exposure to fresh water.
- Constant exposure to salt water.
- Constant exposure to chlorinated water (for when testing in pool).
Other things based on what the PLA is shaped into:
- Small solid infilled objects (such as a printed clasp or carabiner).
- Small objects with 20% infill. Small pieces added to existing accessories (such as a stopper for the reel on your dive flag).
- How thick would container walls need to be in order to withstand pressure.
- Could you even make a container that held together well enough, if you employed rubber seals?
So, what do you think? Looking for answers, helpful advice, or even more questions to add to my list. :D
    • 4 years later...
    You will probably find that regardless of the material you use, the pressure will force water into the piece if it has any infill less than 100%, and perhaps even then, as there are always voids in any printed piece.
    Have fun experimenting, though.
    • 2 weeks later...
    Last year I printed a replacement skimmer flap for my (chlorine) swimming pool, its been installed for more than six months without noticeable degradation.
    The only problem is that it goes green inside - caused by bacteria easily removed by bleach, I plan to re-print but solid this time rather than hollow (with infill)
    My only other thought is that if you print anything which is hollow inside I suspect it will suffer from pressure, from my diving days the volume of air is half at one atmosphere depth, so the plastic would be damanged, so I would try solid (100% infill)
    hope this is of interest
