yellowshark 153
Certainly 12 months plus for me; I do keep them in the plastic bags that Faberdashery ship them in, i.e. loose not wound onto plastic reel/spool
+1 for what Robert said. It sounds more like your filament is reaching the center of the coil, which means that the filament is tighter and the feeder has to work a little harder to pull the filament, causing your feeder to skip. You are not getting the same problem with your other spool... because its not at the centre.... YET
IRobertI 502
I have spools that I've had for a couple of years at least and they work just fine. It could be that you're reaching the center of the spool which is wound more tightly which causes more friction in the bowden tube.
