yellowshark 153
If you still get it after your bed is cleaned then reorient it to another position on the print bed, print again and check the result. It also would be worth you watching the 1st layer go down and see if you notice anything amiss during layer 1
Dim3nsioneer 556
Maybe you want to check if:
- The glass of the heated bed is clean (clean it with a dish washer agent or similar...)
- the glass really lies on the heating pcb/aluminium as many heated beds (UM2 or HBK) suffer from sink bores not deep enough resulting in the glass laying on the screw heads only instead on the aluminium plate
- a reduction of the fan speed improves the situation
