Thanks for the reply!
The machine menu "Home head" seems to just move it forward and right a little over and over. I have done that quite a few times with no improvement. I started playing around with pronterface and sending G28 followed by M114 and the G28 command has some effect. If I move the head manually to the back left of the machine then send G28, the M114 command shows x0.0 y230 z230. I don't know if this is correct or not. Once that is done I have been moving the head in pronterface to the other side of X and Y and in both cases the print head slams into the glass. Once again I dont know if that is ok. Today I noticed some black dust that I suspect is fragments of the gantry belts. I will try to attach a picture.
Is there anything else I can try?
nallath 1,125
The printer has no idea where the head is. Homing is simply moving the printer diagonally untill an end switch is hit. If the y switch is it, that point is now considered to be 0.
Pronterface seems to assume that the direction is different or that the machine (as our older models do have it) have min x/y switches and max x/y switches.
From your profile, I see its an um2. You can simply use the menu on the machine to home it.
