Top surface not closed
3dnerd
Posted · Top surface not closed
from my very 1st print with the UM2 (which is now 6 weeks ago) up to now I see in my print results small thin gaps between the filament paths of the very top layer.
Take a look here:
You can see dark lines between the filament paths. On the right side it is much better. I checked different parts I printed and there is almost every time an area where paths to not fuse together smoothly and show these very thin gaps.
I used different materials already, but almost same problem. Bed is levelled and I get a
homogenous 1st layer.
Here the settings I used for the part on the photo:
Material: Innofil PLA green, printed at 230°
- Layer height 0.15 mm
- Shell thickness 1.2 mm
- Bottom/Top thickness 0.9 mm
- Fill density 25%
- Initial layer thickness: 0.2 mm
- Travel speed 150 mm/s
- Bottom layer speed 20 mm/s
- Infill speed 80 mm/s
- Top/bottom speed 30 mm/s
- Outer shell speed 20 mm/s
- Inner shell speed 20 mm/s
So what I have to tweak to get the top surface more smooth and closed?
Thanks!
    I would try equalising your infill speed and your perimeter speed and see what happens. You are asking the machine to move from 20mm/s to 80mm/s and I am betting it takes some time to get that new pressure equalised. Once it does you the get your section of perfect infill.
        • 21 replies
