A picture of the thing you're trying to print would be helpful. Posting pictures is a pain but here's how.
ABS shrinks a lot when it cools, so that's probably your main issue here. What settings are you using for the fans? If they are going full blast, try setting them to 50% or even turn them off completely if possible. Consider covering the front and top of your printer to keep the chamber heated up.
If the part wont be subjected to a lot of force you could also consider printing it standing up.
stu_le_brew 42
not sure I can visualise exactly what you are trying to print, but maybe you should try with support structures "touching build plate"
good luck, and welcome to the forum too
