70C is too hot for the bed. I know it's the default for most UM2's but 50C is plenty hot for PLA and there is no improvement at higher temps. This could be the problem if the part fell over when you were done and sat on the bed for a full 20 seconds at 70C. But I doubt that happened.
I often think I've seen "every kind of print issue" but this is new to me - I've never printed out something quite this kind of shape. Does it have to be hollow inside? Could you put a vertical support wall touching that curved wall while it prints and cut it out later?
You definitely also want to add brim on the basic tab under "support structure".
Those are my two pieces of advice and will help some things but won't help this issue you asked about.
Could it be fan related? The fan can really make prints better but you don't have any overhangs or bridging that I see so maybe put the fan at 30% and see if that makes any difference - just a guess here.
neotko 1,418
Try again eith a raft. Material compression it's more noticeable on large areas specially if the infill was high (more material more tension while cooling).
