Extruder getting off course
Posted · Extruder getting off course
I got my Ultimaker 2 in Janurary, and have been getting good quality prints for the past 4 months.
I am attending a trade show this weekend, and was invited to bring my 3d printer, so in anticipation, I have printed about 10 objects for example.
Suddenly, starting yesterday, I have been having a problem where the extruder is printing just fine, and then suddenly I hear a kind of grind sound, like the belt is slipping, and the whole nozzle and everything moves to the right about 10mm. And it keeps printing like nothing happened. I have attached a photo. I was printing a vase that should be straight up.
I did buy some sewing machine oil and did oil the x and y shafts, but its still bad.
Any help for this newbie before my show on Friday????
    95% of the time it's a loose set screw on the pulleys. Especially when it's a large sudden move like this. So get a 2mm hex allen wrench and tighten the hell out of the axis that is slipping. It's 70% of the time the one on the motor itself so you may have to remove the cover over the motor which only has 2 screws holding it in. You may have to also separate the motor from the wall which is another 4 screws - position the bed just under the motor so you can rest it on the bed if you need to take a quick break.
    occasoinally it's the other pulley on the short belt. Very rarely it's one of the other 3 or 4 pulleys for that axis.
    Any help?
    I printed an octopus twice and both prints had issues at the same layer.
    So I tried a shorter model. Printed the whole thing, but I had Cura set to do two models. First model went well, but the second failed in 2-3 layers.
    I have no idea why.
    Ideas?
