So I tightened all the screws, including the screws on the motor. But it's still happening.
Happens within only 3-4 layers before it screws up.
Any help?
I printed an octopus twice and both prints had issues at the same layer.
So I tried a shorter model. Printed the whole thing, but I had Cura set to do two models. First model went well, but the second failed in 2-3 layers.
I have no idea why.
Ideas?
gr5 2,229
95% of the time it's a loose set screw on the pulleys. Especially when it's a large sudden move like this. So get a 2mm hex allen wrench and tighten the hell out of the axis that is slipping. It's 70% of the time the one on the motor itself so you may have to remove the cover over the motor which only has 2 screws holding it in. You may have to also separate the motor from the wall which is another 4 screws - position the bed just under the motor so you can rest it on the bed if you need to take a quick break.
occasoinally it's the other pulley on the short belt. Very rarely it's one of the other 3 or 4 pulleys for that axis.
