Local timezone support for forum entries
xisle
Posted · Local timezone support for forum entries
Just fixed it and uploaded it tho...
that's why i had issues when i changed mine about 3 hours ago, it just froze all the time then it took it.... glad its fixed for others now...
    I turned off "Automatic Timezone" and it works now. Changing the timezone manually appeared to work until the page was refreshed.
    Hi guys, there's an issue with the timezone changer. We're looking into it right now and are trying to fix it. Please don't use the timezone settings for now.
    Hi guys, it works again :) you can use both the automatic timezone and forced timezone. However, please take note of the following: if you use automatic timezone the field in forced timezone won't change based on your timezone! We will improve on this in the future.
